Laser Distance Sensor, PMOD Compatible
Laser time-of-flight distance sensor board, PMOD compatible, featuring the VL53L0X ranging sensor
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
This is a PMOD compatible peripheral based on the ST Micro VL53L0X Time-of-Flight laser ranging sensor. It has a range of up to 2m and uses I2C to communicate. The shutdown and interrupt pins are also brought out to the PMOD connector. Specifications: -2.6V to 3.5V input -2m max range -20mW average power consumption -0.7" x 1.0" PCB -Two 2.2mm mounting holes -PMOD compatible pinout -Breadboard compatible
