Heated Bed Thermistor Mounting
A project log for The Print3r
All Metal Triple Extruder Water Cooled Delta 3D Printer
oneohmoneohm 10/05/2016 at 00:020 Comments
This was a 12v aluminum heated bed - I later swapped it for a 24v version. The process was the same however. To start I milled out a small pocket to hold the thermistor:
Finished pocket:
A tiny copper sheet cut to fit the pads intended for the LED indicator:
Securely held in place by the soldered copper sheet:
Lots of kapton just to be safe:
