Parallel Interface - with an upgrade
A project log for Arduino Graphics Card
Advanced graphics for anything from homebrew computers to weather reporting boxes and everything that can communicate over 3.3-5v UART.
dylan-brophyDylan Brophy 07/04/2017 at 14:470 Comments
The propeller is a great chip, it is simple once you get used to it and works very well for simple applications, but its video output could be better:
The solution? An FPGA.
This isn't the first time I have tried to make graphics devices using FPGAs and a parallel interface. Earlier on my #Z80 overpowered compute (possibly before I discovered HaD) I was trying to make... well a Z80 computer, but I overlooked some things and learned some hard lessons. So I had to literally start over. Well anyways I made a semi-nice graphics card designed to interface with the Z80 that also has a VGA connector and 8-bit DAC. It features a Mercury Board that stacks into a makeshift DIP64 socket.
Here is this old board:
I will improve it next time, promise!
And some weird test program I was trying to write for it I found:
Here is the bit configuration of the DAC:
0 red 0
1 red 1
2 grn 0
3 grn 1
4 blu 0
5 blu 1
6 brightness 0
7 brightness 1
This will be a better design than before.
