Gimbal
A project log for FoneTroll II: Gyro-mounted FPV/controller
Static-orientation screen holder with dynamic gyro-based controls for RC vehicles
kendoken.do 05/10/2018 at 19:041 Comment
Having looked at hundreds of gimbals, I am going for cheap, light and simple. Essentially all versions of this are all very similar.
https://www.banggood.com/Light-2-Axis-Brushless-Gimbal-With-BGC3_0-Plug-and-Play-Stabilizer-For-GoPro-SJ-Hawkeye-DJI-Cheerson-p-1104837.html
To attach it, I will flatten a section of PVC pipe ( the piece that goes between the grips) drill and bolt in place.
The gyro unit that resides on the camera base may need to be re-oriented so that the phone/tablet can be attached to the (former) bottom of the gimbal frame. Pics will follow...
Morning.Star wrote 05/12/2018 at 16:00 point
That will be solid ;-)
