Mounting of lift on the car door.
A project log for Rollator lift for small car
Simple car lift for rollator out of some coated plywood, wiper motor, drivebelt and aluminum rails. Walker stored instead of passenger seat.
typotypo 10/03/2016 at 20:210 Comments
A friend of mine did the welding: Four M6 bolts welded directly on the steel of the door - the door panel was removed.
Here you can see the mounting of the backplane:
The black / red belt at the end holds the rollator in up position securely when driving.
