So I bought some boxes...
A project log for Filament storage science
Beware. Plastic containers are moisture permeable.
DeepSOICDeepSOIC 10/04/2016 at 17:441 Comment
So I bought some boxes. Found some desiccant I've collected from various packages with stuff (I've been collected silica gel for just in case). Dried silica gel by heating it to 350°C (was too much, some beads turned brown). Put it into paper bad, and dropped it into the box with filament. I the box, I drilled a 2mm hole to pull the filament through. Sealed it up a bit with tape.
Next, after a day or two I did some printing. It was all right, but not as great as I anticipated.
About a week later, I decided to re-dry the silica gel to see, how much moisture it had adsorbed. To find out that it was probably saturated. At least, it was creating about as much steam as it did the first time I was drying it.
So, it became obvious I need to investigate the problem a little bit more, because re-drying the desiccant every week is not an option!
Also, I needed more silica gel, because the amount I had felt like only enough for one box with one spool. So I bough some silica gel cat litter, which is reasonably cheap, easy to obtain, and coarse-pored (allows to heat to higher temperature, so I can dry it faster).
Jarrett wrote 10/04/2016 at 18:08 point
Pictured:
The latest teenage drug craze, sweeping the nation
