Preparing the files in Inkscape. put stuff in the correct layer, F.Cu for the main copper. For Edge.Cuts i converted the object to path and straight lines. And for testing the drill i just added a circle, random size somewhere.
Here it is in Kicad! No more need to export png, text edit and all that crap of my old workflow!
Checking the drill size. At the moment all circles are converted to the same 0.8mm drill standard. but can be edited locally in Kicad.
then plotting the gerber file and make drill file from Kicad and checking the result in http://viewer.tracespace.io/
ok i didnt have a soldermask layer, so everything is covered (besides the drillhole). just deleted it in the viewer to look nice.
Now testing with more layers…
The inverted SolderMask is working now!
and the output to kicad and gerber runs smootly!
(demo instruction by dusjagr)
Budi Prakosa a.k.a Iyok
mbsg99
youkito1991
rahmanshaber
Bigg Boss 18 is set to be a rollercoaster of emotions, strategies, and unprecedented drama. Whether you prefer watching it live on Colors TV, streaming on Voot, or catching clips on other platforms, there are plenty of ways to stay updated with all the happenings inside the Bigg Boss house.https://biggboss18episode.com/
