Biped Design
A project log for 3D Printed Robot Actuator
A high speed and high torque robotic actuator using low-cost brushless motors, custom controller, 3D printed parts and bearings.
paul-gouldPaul Gould 06/09/2018 at 15:221 Comment
6x Actuators
Do all the joints need the same size actuators?
Are different reduction ratios required? Higher torque less speed.
Dan DWRobotics wrote 06/09/2018 at 16:18 point
This would be immense if realised. As per my message I use the same ratios for each joint, for simplicity but it is probably a good idea to do some calculations.
