Slider
A project log for Linear PCB Motor
An Open Source Linear Actuator
Carl BugejaCarl Bugeja 05/25/2018 at 21:590 Comments
This is the 3d model of the slider for the first linear pcb motor prototype. This slider houses a 2x20mm diameter neodymium n52 magnet that is used to slide across the pcb by the coil's magnetic fields.
