V3/Pro Support
A project log for Monoprice Mini Marlin 2.0 Support
Getting Marlin to run on the Monoprice Mini/Malyan M200.
jc-nelsonJ.C. Nelson 08/14/2019 at 21:241 Comment
Thanks to a discussion on Facebook, I've solidified the V3 pinouts. For those of you keeping score at home, the probe is the old Z-Min pin (PB5) and the Z-min moves to PA2 on the Serial2 header. I'll have a code change for this/PR for Marlin soonish. I don't recommend using this on the Pro or V3 yet because the menu for adjusting the Z offset doesn't work - there's a whole new set of commands I need to implement (P:I, S:S, M:[0-998, 999], where S:S is save settings, M:0-998 sets a Z offset, and P:I initiates leveling).  Also, this will require the failsafe EXTUI support, which has to come first.
Jeff wrote 10/28/2020 at 01:14 point
Has any progress been done on this, I replaced a failed ABL sensor with an LY18 series inductive sensor and doing the level corrections with pronterface suck.  btw I'm Jeff Nelson
