We build a portable water cleaning device which can be use in emergency situations like floods. Our device uses a UV light system to purifie the water.
Instead of using a real UV light for the project we decided to use blue LED's for our project. The wires are connected to the LED's and connected to the dynamo through a USB cable. We used four 500 ohm resistors in our circuit as you can see.
2
waterproof
We build a drawstring to make the circuit waterproof and a part of the USB cable.
3
UV light
Now you have to take the circuit with the LEDS and insert them on the plastic bag. The USB cable is power up by an external battery ( 5V)
