Tool and Flux selection notes
A project log for Nooelec HackRF Shielding Installation
This is a tutorial on how to install the NooElec HackRF Shielding Kit.
jay-phantomJay Phantom 05/15/2018 at 17:160 Comments
I used no-clean liquid flux for this build instead of the usual rosin flux, as it's way way easier to clean off of a board with small components, or extra small spaces it can collect in.
You will also want to find a light clamp to hold the shield down until you tack a couple of the corners.
