Assembling more boards
A project log for Smart Motor Driver for Robotics
This motor driver is able to control a motor using PID by I2C. Taking precise control of a motor have never been so easy.
danny-frDanny FR 06/01/2018 at 19:020 Comments
The first step is to apply solder paste to the pcb. I will use a stencil
And now we pick and place carefully all the parts into the board
Then we put the pcb in the oven, so it can be soldered by reflow method
Finally the boards are done, the next step is to check that everything is ok :)
