Oh no...
A project log for RPi Gameboy
Putting a Raspberry Pi and other components into a Gameboy case for the ultimate mobile gaming console.
cloudiouscloudious 06/13/2018 at 20:560 Comments
I have a disappointing update...I was doing a little size checking and then some research into pi Zero...a raspberry pi 3 will NOT fit into a DS Lite. I do not know enough about doing custom pin changes on the Pi Zero to make everything work using that (mostly audio). So I have decided to change this project from putting a Pi into a DS Lite to putting a Pi into a Original Gameboy case!
