I finally did a test board using PCBmodE, which I've been meaning to try out since the excellent Saar Drimer interview by @Chris Gammell. It's not so much a tool itself, more of a conversion script to allow JSON descriptions to be converted to SVG, or to gerber. It mostly gets out of the way and allows you to draw stuff in Inkscape (or whatever your preferred vector editing suite), so it is Extremely My Shit.
I'm not going to wax on about the cool stuff that's possible with it, so run a Google image search for PCBmodE.
So my test was a pretty simple. It's called Shallow, and is a shallow dive on the features and function of PCBmodE, just to get a board into my hand.
![](https://cdn.hackaday.io/images/3621931528735046713.png)
Of course, @oshpark is the only option for manufacturing these :)
Here's their gerber viewer:
![](https://cdn.hackaday.io/images/6423061528736885080.png)
In my hands:
![](https://cdn.hackaday.io/images/7229241528736950615.png)
Pretty
![](https://cdn.hackaday.io/images/1508331528736974804.jpg)
Purple LEDs are extremely difficult to photograph.
The battery holder components comes from The Lady, the Boldport original ladybug PCB. It's designed to be used with one of those cheap stamped metal CR2032 holders, but I didn't have one on hand. So it was easier/faster to fashion my own out of tin snips.
![](https://cdn.hackaday.io/images/7822031528737126686.jpg)
More about Shallow, including a brief tutorial, is written on my site.
This was a simple board that was okay to design without a schematic, but there was no way I could do that with some of the sophisticated stuff I want to do in the future. The clear solution was to write a conversion tool to convert full Upverter PCBs to PCBmodE compatible files. More on that in a future update!
Board files are here.
I assume that everything on the back is resistors? What value did you use (I ordered some of these from OSHPark).
Hah, awesome!
I think I used 470 Ohm resistors. Really, whatever works to get whatever your LEDs running off a 3.0V battery
thx. I tried 470, ended up going with 330 which I happened to have lying around. Now to figure out a brooch mount!
Do you have a part number for the LEDs you used?
No part number. Here's a link though:
https://www.aliexpress.com/item/100pcs-0603-1608-Purple-UV-LED-Chip-20mA-Surface-Mount-SMD-Diode-Ultraviolet-395nm-400nm-SMD/32821243748.html
Really nice looking board! That detail all the way down the the middle section looks great and showcases the PCB artistic medium quite well.
Awesome board! Interested to see how you approach more sophisticated projects; my holdup on PCBmodE has always been its lack of integration with EDA. Looking forward to seeing an example with your Upverter-converter.
This is fantastic! Well done!
