A Quick History
A project log for Krusty The It
A Terrifying Clown - TwinkleTwinkie's DC26 Shitty Add-on #1
twinkletwinkieTwinkleTwinkie 05/29/2018 at 18:180 Comments
I am actually on my second revision of this board.  The initial revision had a place for a 0805 Resistor which turned out to be unnecessary.  Of the 140ish I'll be bringing to DEF CON approximately 45 will have a ZERO OHM Jumper where a resistor would have been.
The second revision doesn't have this and I carried this knowledge over to my second shitty add-on.
