Badge Modem
Connecting on wireless network and BBSing made on Hackaday Conference badge
Badge is from 80' . In that time popular was BBSing era before internet for communication, etc...
Badge is communicate via UART to NodeMCU but you can use other ESP8266 chip. Modem communicate with AT commands.
My plan is to make shield for pins where you can just plug and play Wireless Card.
  • 1 × Badge from Belgrade Conference
  • 1 × ESP-12F
  • Prototype v2 Badge Modem
    bosko10/03/2018 at 11:02 0 comments
    Here is schematic of prototype version 2 of BadgeModem. In this prototype i was use ESP-12F and test was successful. I made it to be just simple plug and play.
    Simple add modem to badge, load program and thats all.
    Schematic
    Closer look of prototype
  • Prototype of Badge Modem
    bosko06/20/2018 at 11:36 0 comments
    Here is schematic of BadgeModem. In this prototype i was use ESP-01 and test was successful. I made it to be just simple plug and play.
    Schematic
    Testing Badge Modem
  • Demo video
    bosko05/31/2018 at 17:22 0 comments
View all 3 project logs
  • 1
    BASIC Code
    5 a = 0
    10 if a > 0 then goto 70
    20 if a < 0 then goto 70
    30 r = uin 0
    40 chr r
    50 a = kin 0
    60 goto 10
    70 uout a
    75 a = 0
    80 goto 10
  • 2
    NodeJS Simple Server
    var net = require('net');
    var sockets = [];
    function cleanInput(data) {
    	return data.toString().replace(/(\r\n|\n|\r)/gm,"");
    function receiveData(socket, data) {
    	var cleanData = cleanInput(data);
    	console.log("received " + cleanData);
    	if(cleanData === "@quit") {
    		socket.end('Goodbye!\n');
    	else {
    		for(var i = 0; i<sockets.length; i++) {
    			if (sockets[i] !== socket) {
    				sockets[i].write(data);
    function closeSocket(socket) {
    	var i = sockets.indexOf(socket);
    	if (i != -1) {
    		sockets.splice(i, 1);
    function newSocket(socket) {
    	sockets.push(socket);
    	socket.write("Hello Hackaday Badge\n");
    	socket.write('_  _ ____ ____ _  _ ____ ___  ____ _   _\n');
    	socket.write('|__| |__| |    |_/  |__| |  \\ |__|  \\_/ \n');
    	socket.write('|  | |  | |___ | \\_ |  | |__/ |  |   |  \n');
    	socket.on('data', function(data) {
    		receiveData(socket, data);
    	socket.on('end', function() {
    		closeSocket(socket);
    var server = net.createServer(newSocket);
    server.listen(8888);
View all instructions
morgan wrote 10/04/2021 at 16:10 point
Super cool! I did similar for SuperCon 2018! It's super cool to seem to have managed to control from BASIC. That was one of my goals but lack of string support hindered that. We ended up writing a companion 'app' for the Badge as well as ESP32 firmware.
https://hackaday.io/project/161906-attention-supercon-addon
Kosma wrote 10/04/2021 at 15:03 point
How long this device work on one charging battery?
a week?
Kosma wrote 09/30/2021 at 08:46 point
can You add sound modem? very simple.
microphone and sound emiter, connect to baofeng and send receive digital data on any band (ISM, PMR etc)
bosko wrote 09/30/2021 at 21:11 point
I cant add in this badge, but with external arduino i can do that, with serial communication to MicroModem you can communicate with APRS example.
Kosma wrote 10/04/2021 at 14:54 point
why You cant add this? Yes aprs or mesh / pocket radio sound good.
this modem no need real sound card, only send electric signal (very slowly, 1200 signals per second)
