Microcode Breakpoints
A project log for BREDSAC
Electronic Dynamic Storage Breadboard Computer
gregewinggreg.ewing 10/26/2018 at 12:100 Comments
While debugging my multiplication instructions, I decided that I needed a way to set a breakpoint in the microcode. I added some manually-controlled inputs to specify the microcode address, multiplication step count and bit number to break at, and a breakpoint enable signal. To make the wiring a bit tidier in the main circuit, I also grouped all the microcode address lines into a bus.
The Microcode Breakpoint subcircuit compares the current values of the microcode address, multiplication step and bit number with the breakpoint values. When they match, and breakpoints are enabled, the UBREAK output is activated.
UBREAK is connected to the Run Control subcircuit, where it disables the RUN output, freezing the rest of the machine. To allow continuing after a break, I made some other changes to the run control circuit. When the CONTINUE button is pressed, a pulse lasting a single clock cycle is generated by Cont FF 1 and Cont FF 2. This pulse temporarily overrides the UBREAK input and allows a BITCLK cycle through. Since this advances the bit counter, the break condition will no longer be met in the next cycle, so execution continues until the breakpoint is reached again or the nachine is stopped by other means.
The Stop FF is no longer needed and has been removed. The Run FF is now set directly by the Continue pulse.
