Front Panel Deposit Operation
A project log for BREDSAC
Electronic Dynamic Storage Breadboard Computer
gregewinggreg.ewing 07/26/2020 at 07:170 Comments
The Run Control subcircuit now has provision for initiating up to four different non-instruction microcode sequences (NIMS). The inputs for triggering these are first latched to synchronise them with BITCLK, and then fed to a priority encoder which generates a microcode address. At the same time, the Continue FF chain is activated, producing a one-BITCLK pulse at XUSTART and then setting the Run FF.
NIMS Timing
Run Control
Instruction Register Loading
I found a problem with the logic for loading the NIMS entry point address into the instruction register. It doesn't work if the instruction register is clocked with RUNCLK, because the XUSTART pulse occurs before RUNCLK is activated. So the instuction register is now continuously clocked with BITCLK, and functions that should only occur while the machine is running are gated with RUN.
Input Switches and Parallel Input Bus
I added a set of switches for manual data entry1. These are gated onto a Parallel Input Bus (PIB) which connects to new parallel inputs on the S register.
There is currently only one data source for the PIB, but there will be others later. I needed a way of selecting the PIB source in the microcode, but there are no more bits available, so I have re-used part of the UBADDR field. This means I won't be able to perform a microcode branch and use the PIB at the same time, but I don't think that will be a problem. The function of the Deposit switch will be to write the value from the input switches into memory at the address currently in the PC, and then increment the PC. To do this, I need to be able to select the PC as the source for the memory address, and increment the PC, independently of other functions.
I also need to be able to select the serial output of the S register as an X source in the ALU input selector.
Deposit microcode
# XSEL values
XSR  = 011  # S Register
# MISC values
PLS   = 1110  # Parallel load S register
LDPC  = 0001  # Load PC from IR
INCPC = 1001  # Increment PC
MAPC  = 0101  # Memory address = PC
# Deposit
   1 00000 0 0000 :  -   -   --  ---   -  --    -     -   --   -   -   -   -   -    -   PLS     -   ---    PISW -- # Load switches into S
   1 00000 0 0001 : SHS  -   --  XSR   -  --    -    WMEM --   -   -   -   -   -    -   MAPC    -   ---    ----    # Write S to memory
   1 00000 0 0010 :  -   -   --  ---   -  --    -     -   --   -   -   -   -   -    -   INCPC   -   ---    ----    # Increment PC
   1 00000 0 0011 :  -  EOI  --  ---   -  --    -     -   --   -   -   -   -   -    -   HALT    -   ---    ----    # Stop
Footnotes
1. This is not quite historically accurate. The EDSAC designers deliberately did not provide a way for users to enter programs manually, because they didn't want people taking up machine time debugging at the console. It did have a set of "engineering switches" that were used for maintenance, but I don't know exactly what they did or how they were used.
