Updated Body Heat Powered Headlamp Process
A project log for Body Heat Powered Flashlight
Infinity Flashlight Powered by Your Own Body Heat
wasim-sahuWasim Sahu 10/21/2018 at 14:550 Comments
Sketch the Head lamp
Before we make a actual head lamp first we will make sketch then make a real as it.
Updated heat sink
This is almost the same headlamp like previous but having updated heat sinks light weight and having lags. Actually a heat sink having more legs give better results. In previous head lamp we used aluminum blocks of heat sink. Hard wire length 43 cm heat sink squire size
40.5mm we need. Strips size are respectively  22,1 cm and 32,2 cm
Other steps are as same as the previous headlamp these pictures will help you how to connect peltiers with heat sink using thermal past.
