Hackaday.io Hackaday.io
Sign up Log in
Acryl Nixie Watch
An Arduino based watch-version of my Acryl Nixie Clock
cfCF
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
4 comments
14 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 4
View Gallery
4
14
14
Team (1)
  • cfCF
Join this project's team
hardware
ongoing project
WAtch arduino charlieplexing led
This project was created on 06/14/2018 and last updated 8 years ago.
Description
The PCB is made of three parts. The LED-PCBs are soldered at a right angle on top of the main PCB. The LEDs are charlieplexed. Two LEDs will light up one sheet of plexiglass. The glass itself is 0.5mm thick and 8x16mm wide. It's just a first proof of concept. I'll work on better light separation of the LEDs/glass plates by now.
Details
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Starhawk wrote 10/10/2019 at 20:28 • point
WANT. How much fer a kit?
Mike Szczys wrote 06/14/2018 at 19:01 • point
This looks really cool!
Are you scanning the charlieplexed LEDs or are the constantly on? I ask because I notice that the higher the number, the less bright it is (maybe it's less obvious to the human eye than to the camera). If you can make the LEDs on the lowest acrylic sheet full brightness, and PWM the ones closer to the surface down you may be able to balance the appearance of all digits.
I love the look of the stack-up from the side. A great detail for the wearable piece; it's nice to show off what's special about the design.
CF wrote 06/14/2018 at 19:55 • point
If you know how much LEDs have to be one you can skip the other ones and increase the brightness. That's how I did it also with my other watch projects. The schematics behind each watch is nearly the same. Since the Atmega can provide only a certain current you can also skip any protective resistor for the LEDs.
Mike Szczys wrote 06/14/2018 at 21:49 • point
interesting, I don't think the ATmegas are current limiting though, are they? I think the spec is there so that you design for that current or less.
I've always wondered about doing peak current on visible LEDs. I know that IR LEDs have a high peak current and that's how handheld remotes are so good. Can you get a spike of brightness from an LED for a short period of time to make up for the off-time during scanning?
SMART LED FLASHLIGHT - a tiny personal emergency Light sensing LED flashlight, made from available components and very simple for replicate
Project Owner Contributor
httpwhite-robotcomhttp://white-robot.com/
...not just LEDS placed under the glass surface. Those LEDs are on the floor level, and stretch infinitely
LED table, but...
voja-antonicVoja Antonic
A shiny PCB ruler
Kitspace PCB Ruler
kaspar-emanuelKaspar Emanuel
The 2017 Hackaday Prize
An optical beatbox for interacting with light-sensitive synths... and maybe other devices?
Optical Screwdriver
john-baichtalJohn Baichtal
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Acryl Nixie Watch", please tell us the reason.
Send message
Remove Member
