OK so first I want to say the original model I found on thingiverse. I am not using the whole model and the parts I am using will be modified so It will really not look the same in the end. I downloaded 123d to play with the parts and make what I need. I need to make a base, the petals and chop them up for printing a larger scale than I can get all in one print. I will print the first pieces tonight. I am off tomorrow to work on some of this. The petals will be lights with silver to reflect heat towards the center which will be fabricated with copper wire.
