When you look directly at the flower you can see the angles of the petals reflect light. Once Mylar reflective film is covering the leaves this should reflect heat to the center like a mini solar oven.
A project log for Lily Power Pods, TEG + Concentrated Solar
Thermal Electric Generator from concentrated solar, designed to float in water, small scale power anywhere in the world.
