Drama over, back to work again
A project log for Witcher Wi-Fi Medallion MK2
Didn't like the metal necklace, so PCB art was the way to go.
torbjrn-lindholmTorbjörn Lindholm 07/09/2018 at 17:490 Comments
Apparently due to some unknown reason KiCad wrote several hundred of zero-width tracks that point to the same place, causing the algorithm to spiral out of control. Removing those lines has made the fill work again.
Evidence #1: Text log of the crime
I'd like to thank u/toybuilder on Reddit for the help!
