prototype 2 starting
A project log for Cyborg 360 Flir AR HUD Motorcycle Helmet
Worlds Largest 7" Diagnal personal AR display in a motorcycle helmet, see 360 degree view, smart interface. Flir, IR and Ultrasonic
josh-starnesJosh Starnes 08/10/2018 at 22:080 Comments
OK so this begins try 2, this is nor a hardware or implementation issue, I simply had a happy accident and found that another cheap headset has some features I could exploit. Of course in the name of open builds I want to use something easily attainable by the maker community, that being said I found the Lenovo Jedi Challenger game headset to have a set of optics that I think would work great to exploit! I found one as low as 45 dollars then offered $30  and the seller accepted it. Boom , replacement on the way.  These are regularly 40-60 on ebay because the game itself is a bit of a flop for the price. This headset has a clear outside lens that I think I may be able to use in the end and would look better that piece work. I will still post 3D printable versions and VR goggle conversion instructions as well so everyone can join the fun!
