New 3D printed tCam-Mini enclosure
A project log for Lepton 3.5 Thermal Imaging Camera
Documenting my experiments with the FLIR Lepton 3.5 thermal imaging camera.
dan-julioDan Julio 03/02/2022 at 02:410 Comments
I finally had some time, after the holidays, to build a Prusa i3 MK3 3D printer and I've been having fun using it.  It's a fine machine.  I also took a little time to design an enclosure for tCam-Mini.   The basic enclosure is comprised of two pieces, a base and a bezel, held together with 4 4-40x5/8" metal screws with the tCam-Mini board captured between.  There are two different designs for the base.  One for the existing Rev 2 PCB and one for the upcoming Rev 4 design.
There is also a three piece GoPro™ compatible mount that clips onto the enclosure.  It's light and designed to be the thing that breaks to support tCam-Mini on a drone.
The design is in OpenSCAD and both the design and STL files ready for slicing may be found on my website or in the github repository.
