I finally had a moment to add the tCam-POE hardware design to the tCam github repository. tCam-POE is basically tCam-Mini but with the ability to connect via ethernet instead of Wifi and also supports IEEE802.3af POE power. No word yet if Group Gets is planning to build this. Let them know if you would like to see it as a product. :-)
