so i encounter with some errors that I didn't expect, for starters, the outline of the board is great but, it doesn't fit under any grid, at least not any common grid, so I had to trace a new outline as similar as i could, taking the original ar a reference and erasing the original, this gave me a little more work, but now i have and standard board shape
and then, when i moved the board around, the silkscreen moved, but not fully, so this happened
so there's another time redoing the silkscreen and moving it around, in order to see if there's any error. this took longer than expected due to the process of verification (do something, move, save, next)
when i finished this, i noticed that i couldn't panelized it correctly, due to the form of the board (the upper part of the logo) so, i had to modify the outline again in order to make it a little more square per say, this was an easy fix, so no big deal
RRichmond
