I added a bypass switch.
It disconnects the outputs and shorts the generator to 0V, so you can check that everything works well (for example, if some saturation is suspected). You don't need to short the output with a wire to set the max current :-)
Because this is how it looked before :
... less elegant, right ?
Yann Guidon / YGDES
