Clutch
A project log for P1 - Buddha Tape feeder
3D printable Pick and Place tape feeder for the Arcus-3D-P1.
Daren SchwenkeDaren Schwenke 07/31/2018 at 20:250 Comments
Revised the clutch so the cover idler gets more meat on the bearing.  It needs to be a press fit as the hub pulling down on it is what provides the clutch pressure.
Advantage in that now it's completely obvious where the O-ring goes, disadvantage in that now you have to use the right size.  Before it could handle a pretty wide range of thicknesses as it was a wedge.
