Managing complexity
A project log for IO881
An I/O Processor for 8-bit systems
JulianJulian 07/26/2018 at 01:370 Comments
With a system that handles large volumes of data and tries to keep that data into distinct channels, it becomes very easy for the complexity to get out of hand.  I hard started my design with the idea that every channel has certain kinds of data and each of those needs a separate register ... very quickly I ended up with a monstrosity that needed so many registers the board would have been huge.
Taking a step back, I've decided to simplify things a little, by making the design a bit more general, and using that generality to implement as much as possible.  So, the current thinking is:
My aim is to be able to pull a byte from DMA, extra 2 4-bit fields from it, and push the two results to output ports, all in 4 cycles.  That'll require some efficient implementation, but I hope it will be possible.
