Schematic draft
A project log for ESP32 CANbus shield
Log and display CANbus messages with ESP32
Johan WestlundJohan Westlund 07/22/2018 at 18:500 Comments
A not completed schematic, but the essentials are there.
Seams like devkitC is a popular devboard but have to continue to look.
SD-card connection from this example: https://github.com/espressif/esp-idf/tree/master/examples/storage/sd_card#hardware
Have to check other sources as well.
Will change the input connector to a green screw or snap-in connector with a low profile.
Next update with a draft PCB
