Setup
The first thing you need to do is go to the Ubidots for Education websiteand create an account. You can sign in directly if you already have a Twitter, Github, Google or Facebook account.
When you have already created your account you will have access to your token, bu clicking on your username at the top right corner and clicking on API Credentials. Save your token, as we are going to use later on.
Ubidots Dashboard
Ubidots Dashboard
Token key censored, because I dont want strangers to control my home lights randomly
Jason App
The app can be downloaded from the Play Store, it is available in english and spanish.
Copy your Ubidots token into the app, by tapping the settings tab, pasting it in the Ubidots key field and tap the save button.
Settings tab
Settings tab
Ubidots Key Field
Ubidots Key Field
Saved Key in Jason
Saved Key in Jason
Now we need to configure a device, go to the devices tab, and tap the add button. Enter a name, preferably the name of the area where the lights are, so you can say "Turn on the kitchen lights". On the ESP32 I/O Pin choose "5", which is going to be the NodeMCU (internal ESP8266) pin connected to the relay. And tap save.
Making the Hardware
Safety First
In this project we are working with mains voltage (A/C voltage) which is dangerous if you don't know what you're doing, be very careful. NEVER touch ANY part of the circuit or work with it if it is connected to the wall power. If you don't know what you are doing, stop right here or get some help from professionals.
I am only posting this educational tutorial and I am by no means responsible for any injuries or damage you may cause.
Schematics
Schematic designed in Eagle CAD
NOTE: VCC 5V is going to be supplied from an usb cable connected to a simple phone transformer charger.
Breadboard
Breadboard without external components (AC, switch and USB power supply)
The switch can be a simple toggle switch or a wall switch, it just needs to detect if the user changes its state so we can still control the lights with a normal switch.
Wall Switch Front
Wall Switch Front
Back of switch
Back of switch
The switch that I used has double throw, we only need one, so I connected its pin 1 to 3V of the NodeMCU and pin 2 of switch to NodeMCU pin D8.
Switch connected to breadboard using jumpers
The power supply is going to be a phone wall charger of 5V with a stripped usb cable.
Power connection with jumpers and alligators
By controlling the ground connection with the relay we can control the AC status of the light bulb.
AC light bulb connections (Neutral to relay1, relay2 to negative of light bulb, live to positive of lightbulb)
Alligators comming from the light bulb to relay
Code
Before you use the source code, you need to download some libraries:
Note: If you don't know how to add libraries to the arduino IDE, you can follow this easy tutorial.
Set your development board to NodeMCU 1.0 (ESP-12E Module).
You need to change some variables in the code:
And finally upload your code to the board.
It works! If you have any questions or suggestions please leave them at the comments section.
Schematics
NodeMCU Schematic
Schematic ioohp6x8rr
