Connect devices to obniz as below and place it in your house.
2
Step 2
Write programs written below. Change obniz id in the example. By clicking "Save&Open", You can see a temperature.
3
Step 3
Record a your air conditioner signal for ON/OFF.
The example contains comment outed code for IR receiver. Remove the comment out and record your air conditioner's ON/OFF signal. Your signal will be showed in log.
