IT'S ALIVE!
Today I finally received the jumper cables. I hacked through the Mitosis and Interphase source code and came up with a sort-of-working firmware to test everything.
After a few minor initial problem (might have set the wrong addresses) I made it work.
I programmed and then wired the Core51822 module to the keyboard matrix, it successfully scans the matrix and sends data to the receiver.
Here's some footage of the keyboard working.
I plan to write a proper firmware in the following days, design the PCB and manufacture it. I'm really looking forward to it!
