Finished wiring Endstops
A project log for Jadoo's All in one
An all in one DIY lab in a box 3d printer, laser cutter Heated Chamber and Exhaust removing enclosure.
eric-jadooEric (Jadoo) 08/21/2014 at 04:160 Comments
This past weekend I dove in and finished the end stops the stage now seems to home nicely aside from one off spec polished rod, which doesn't travel as smoothly as the others. Aside from the wiring I have milled a mounting bracket for a depth gauge which I will use to calibrate the bed.
