December Update
A project log for Line Following Drone
A drone that can follow a line on the ground using computer vision, can implemented to follow rivers and map ecosystems.
nehaNeha 12/07/2018 at 15:500 Comments
So far I've found which specific parts I want to use.  I've decided on using BetaFlight and CL Racing F4S Flight Controller with a built in PDB and Aikon AK32 4-in-1 35A 6S BLHeli32 ESC. I've also found motors (Lumenier MX2206-9 2450KV Motor). For propellers, I'm going to use 5x4x3 propellors.
