More Thermostats? Most likely yes, but there is more in the queue.
A project log for eForth for cheap STM8S gadgets
Turn cheap modules from AliExpress into interactive development kits!
thomasThomas 04/07/2017 at 05:310 Comments
I didn't forget the "cheap Value Line" part of this project, but reverse engineering a gadget takes some time, writing and testing board support code even more (especially if there are many constraints, like in the case of the W1401 or the DC/DC converter).
The following boards are in the queue:
The W1219, and the M188 might be the next boards to get a board folder, and a binary release. I'm open to requests, though :-).
Edit: the is an interesting W1209 related report about serial interface problems. Maybe I'll have to change the default serial interface of that board. Issue contains a test binary using a board key instead of the analog sensor header.
