Create a new class of water craft which:
- Primary living levels standing at least 100 feet above the water level, out of reach of any Draupner (highest recorded rogue) wave.
- Primary flotation chambers below the level of high seas (about 60 feet).
- Many redundant flotation chambers with dynamic buoyancy, which can adjust for weight changes and shifts from above.
- Underwater, controllable wings to maintain a level attitude while the craft is moving through the water.
- Dynamically moving and retractable outriggers which maintain a level attitude when the craft is not moving.
- Retractable outriggers with engines and propellers in the back for powered movement.
Secondary requirements:
- Automated retracting sails for efficient low cost movement.
- Levered outriggers which can capture wave motion for:
- Electric power
- Desalinization
- Compressed air for flotation chamber dynamics
- Underwater air tank for holding compressed air for flotation chamber dynamics
- Extendable underwater feet for multi-point anchoring
- Elevators for deploying and loading secondary water craft, people, and cargo
Real estate is a tangible asset that can help diversify your investment portfolio. By investing in Toronto real estate, you can spread your risk across different asset classes, reducing the impact of market fluctuations https://karinrotem.com/.
