Fixed USB Extension
A project log for Hackulator
A Ti-83 Calculator with a Raspberry Pi Zero W, touch screen, Mini HDMI Output, and Li-Ion Battery
melissa-leblanc-williamsMelissa LeBlanc-Williams 09/17/2018 at 01:180 Comments
I fixed the USB extension on the bottom of the calculator so all hardware is now working. On the software side, placed code to control the backlight in a script and I'm trying to get it to run the script on shutdown. I may decided to actually create a simple service if I can't get that to work consistently.
