I've been trying to finish up the housing over the past 2 days. I think I'm pretty close to being done. Currently printing out a couple quick prototypes on my FDM machine to test fit everything and if everything looks good I'll send it to the resin printer.
I've started laying out the Arduino code and have been playing with a couple of the audio shield's features. I'm not entirely set on what I want each button to do, but hopefully after a bit of messing around it'll start to become a little more obvious.
In the meantime, check out some renderings I did of the enclosure:
