2nd September: Solved!
A project log for WildDrone Locator
"Safety First!", we often hear. Mounted on a drone, this beacon says "I'm here!" in LoRa language.
mihaivdrMihaiVDR 09/30/2018 at 21:140 Comments
Yes, we solved it ! And here's how.
Indeed, the almighty oscilloscope proved that the thought from the previous log is correct. The D5-R14-R15 divider does not drop below 0.4V long enough to turn the NCP705 off.
And here is the work-around: a 1uF capacitor.
Fig. 1: Additional 1uF capacitor.
Fig. 2: Additional 1uF capacitor, soldered in top of R15
We also modified the value of R14 (was 47K, now is 100K) and the reference voltage divider. The power-down did not work reliably at low battery voltages.
Fig. 3: New reference voltage divider values.
