5-th September: Enclosure design ready!
A project log for WildDrone Locator
"Safety First!", we often hear. Mounted on a drone, this beacon says "I'm here!" in LoRa language.
mihaivdrMihaiVDR 09/30/2018 at 21:310 Comments
Just as the title says: it's ready. I even created a logo. Probably not the most original logo: a paper plane and some arrows pointing at it. After all, it's a locator for small planes, right ?
Fig. 1: The antenna comes out through a wall.
Fig. 2: The gray cube at the bottom is the LiPo cell.
Fig. 3: The bottom is fixed with screws to the top, but the holes are extruded directly from the bottom part. As they are not overlapping, the holes do not appear.
Fig. 4: Compact enclosure.
The logo extruded cuts will be filled with white epoxy. The button will also have an epoxy fill. most probably red. It will look like a record button, but hey, that's what it does in the end.
Let's hit the printer...
