1st Nov 2018-Thursday
Exploring on Props Making
Prototyping progress:
This week we only focus on prototyping. We built up a miniature prototype mini market which called "Kedai Runcit" in Malaysia. Besides, we also built up the exterior and interior too to let us more easily arrange the placements. After that, we continue to made our little props.
-Refining design
-More prototyping, improving the mechanism and interacting part.
-Did some attempts of the measurements of different parts to make sure it is fit.
We did some simple coding for testing the mechanism
void setup() {
// put your setup code here, to run once:
pinMode(3, OUTPUT);
analogWrite(3,30);
void loop() {
// put your main code here, to run repeatedly:
}const int buttonPin = 2; // the number of the pushbutton pin
const int ledPin = 13; // the number of the LED pin
// variables will change:
int buttonState = 0; // variable for reading the pushbutton status
void setup() {
// initialize the LED pin as an output:
pinMode(ledPin,OUTPUT);
// initialize the pushbutton pin as an input:
pinMode(buttonPin, INPUT);
void loop() {
// read the state of the pushbutton value:
buttonState = digitalRead(buttonPin);
// check if the pushbutton is pressed. If it is, the buttonState is HIGH:
if (buttonState == HIGH) {
// turn LED off:
digitalWrite(ledPin, LOW);
} else
if(buttonState == LOW) {
// turn LED on:
digitalWrite(ledPin, HIGH);
Motor spinnig:
int mot1 = 8;
int mot2 = 9;
int en1 = 10;
int val = 0;
void setup() {
pinMode(mot1,OUTPUT);
pinMode(mot2,OUTPUT);
pinMode(en1,OUTPUT);
digitalWrite(mot1,HIGH);
delay(5000);
void loop() {
