Confirmed Idea_Attempt 3
A project log for Little Thoughts_A Capsule Machine Project
Sharing & exploring each other’s unique values.
anthony-chinAnthony Chin 10/11/2018 at 09:510 Comments
11 Oct 2018
Mechanics Reference
Video reference for capsule machine
Mechanics Sketch
  1. Write a message and toss into the capsule machine
  2.  (A) sensor detect if people toss the ball in, if yes the latch we open for the ball to enter the machine.
  3. At the same time the notch will be unlock, for use to spin
  4. (B) while spinning the notch the "ball holder" will lead the ball downwards to the collect area
How do the notch works
  1. There will be 2 latch blocking the notch from spinning
  2. Once the sensor is checked, another motor above the latch will pull it up
  3. and now user will be able to twist the notch.
Reference
