Putting all thing together
A project log for DIY Drum feeder
Automatic supply of small parts
yvo-de-haasYvo de Haas 11/25/2018 at 14:490 Comments
With the drum attached, everything is working on the drum feeder. Below are 3 videos. 1 of the pins being fed, 1 of the springs being fed, and 1 of the springs being fed, but with a chute at the end.
The videos also include some shots from the inside of the feeder. Normally speaking you would need 2 different linear guides for different products (and maybe even different drums) but the springs and pins share a lot of the same dimensions. In the next log I will share a side by side view of assembling the connector. One by hand and one with the drum feeder.
