Hackaday.io Hackaday.io
Sign up Log in
Let's hack my ruler
Marking gauge DIY - Trusquin DIY
chaosbcchaosbc
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
5 followers
  • Description
  • Details
  • Files 7
    • View all
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
755
0
5
4
Team (1)
  • chaosbcchaosbc
Join this project's team
completed project
This project is submitted for
  • Hackaday.com Tip Line
This project was created on 11/04/2018 and last updated 8 years ago.
Description
Marking gauges are a blast. They save a ton of time when you need to draw lines on a piece of wood (for example) and it is more precise also. The fact is I need one. I have an aluminum ruler, I have a 3d printer, I am a skinflint and I don't want to wait one month to receive a marking gauge from asia.
Details
Files
trusquin_sketchup~.skp
x-koan - 1.29 MB - 11/08/2018 at 18:34
Download
trusquin_molette2.stl
Standard Tesselated Geometry - 15.60 kB - 11/04/2018 at 23:40
Download
trusquin_molette.stl
Standard Tesselated Geometry - 16.20 kB - 11/04/2018 at 23:40
Download
trusquin_penholder-PART2.stl
Standard Tesselated Geometry - 73.67 kB - 11/04/2018 at 23:39
Download
trusquin_penholder-PART1.stl
Standard Tesselated Geometry - 108.29 kB - 11/04/2018 at 23:39
Download
View all 7 files
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Using ABS, PC, PEEK pellets, and magic I will make filament for my Stratasys Dimension SST printer.
Project Owner Contributor
ABS, PC, PEEK plastics research project
austin-tomsonAustin Tomson
It’s one of the underrated tools that you’re probably not using. Continue reading & you’ll see why you need to start taking advantage of it.
How to use the Web Tool in Fusion 360
vladimirVladimir
The elevator
3D Printer - T17 (2019)
chip-barkChip Bark
Polarizing ideas
3D Printer - T103 (2023)
chip-barkChip Bark
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Let's hack my ruler", please tell us the reason.
Send message
Remove Member
