Arduino Software i2c library
A project log for Aquariumatic
Automated aquarium monitor with Web GUI. daisychain units can control multiple tank all from the one master unit. PI/Arduino/ESP Powered
craig-hissettCraig Hissett 11/19/2016 at 11:150 Comments
Software i2c Library
This is just a note to myself really :-)
In order to simplify the chaining of slaves to master I wanted to keep the i2c bus free of any devices other than the slave units (the arduino nanos).
Using i2c displays on the same bus would complicate the process; each slave having two i2c addresses, the screens all carrying the same address etc.
The ideal solution would be to use a library such as this one to create a second bus, just for the screen. this second bus cpild also be used for any further i2c devices added to the slave unit if necessary.
