- wrote some more Atmel code last night to implement a thermal cut-out at about 75-80C
- steamed the ATTiny85 off the Digispark board and dead-bugged it onto the light PCB, made connections with enamelled wire
- all seems to work ok
- will re-fit front glass and take it for a spin tonight, to see if I can let the magic smoke out. :)
