K40 Exhaust Fan Hack
A project log for I want a Laser Cutter!
My Home Laser Cutter Journey
Hari WigunaHari Wiguna 12/24/2018 at 17:020 Comments
Sorry, I don't remember where I learned this from, but someone noticed that there is quite a gap between the fan and the cage on the stock exhaust fan.  Adding a nut decreases that gap and hopefully improves efficiency of the fan.
Had to trim the top of the fan to screw the plastic cap in.Nut was just a bit too tall.  I had to shim the cover with two cardboard pieces so the fan would clear the cover.
